[postgis-users] connection postgis by ArcMap
marco vieira maovieira at gmail.com
Thu Mar 23 06:34:52 PST 2006
Jaromir:
  See the version of your Data Interoperability (FME build in fact). Maybe
it can connect only with older versions of PostGIS (0.9x).
Regards.
2006/3/23, Jaromír Kamler <kamler at centrum.cz>:
> Hallo,
> I want connect to PostGIS by ArcMap:
> postgis_full_version
> POSTGIS="1.1.1" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> I have ArcGIS 9.1. and licence for data interoperability, when I select
> some layers in ArcCatalog from PostGIS server and insert them into ArcMap it
> fail: Application Error The instruction at 0x77fcb0c8 referenced memory at
> 0x01500050. The memory could not be "written".
> Does anyone expirience with connecting ArcMap to PostGIS server?
> Thanks for your advices.
> Jaromir Kamler
> postgis-users mailing list
Marco Vieira
+55 21 9499-6800
e-mail: maovieira at gmail.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060323/b6fe1e2b/attachment.html>
