[postgis-users] X() function working for POINTs and MULTIPOINTs
Bernhard Reimar Hoefle Bernhard.Hoefle at uibk.ac.at
Sat Mar 25 01:27:06 PST 2006
> Hi, Bernhard,
> Bernhard Reimar Hoefle wrote:
> > The PostGIS x() function does not support MULTIPOINTs and the geometryN()
> does
> > not support POINTs.
> > select x('MULTIPOINT(1 1 1,2 2 2)'::GEOMETRY);
> > ERROR:  Argument to X() must be a point
> You might want to write your own set returning plpgsql function. This
> way, it is even possible that select your_x('MULTIPOINT(...)') returns
> two rows, 1 and 2.
> HTH,
> Schabi
Hi Markus!
I was thinking of plpgsql functions. How would such a function look like? I
don't know how to write a plpgsql function which works like the dump()
function. I just know to write a function like SELECT * from
But my problem is performance and the C functions are quite faster than the
procedural scripts.
Indeed, I do need a function like
SELECT id, your_x('MULTIPOINT(1 1 1, 2 2 2)') from table1;
returning
id|x
1|1
1|2
I was thinking of adapting the C code of the dump() function for my purpose.
What do the PostGIS insiders think is the fastest solution for my problem?
The easiest solution is a combined usage of geometryn() and x(), or writing a
plpgsql script which checks how many geometries are in the MULTIPOINT object
and  loops over the geometries with returning the individual values.
Bernhard H.
