[postgis-users] Re: Status of geocoding functions in PostGIS?
Mark Thomas
javaguru at ieee.org
Thu Mar 30 20:48:41 PST 2006
Jeff Hoffmann <jeff <at> propertykey.com> writes:
> Alex Smith wrote:
> > Did some searching of the archives and found this article stating that a
> > geocoder for PostGIS is in the works (see
http://postgis.refractions.net/pipermail/postgis-users/2004-September/005762.html).
> > Just wondering the status of this project and if there is a time line
> > for the release dates.
> I don't know the status of this project, but here's a quick and dirty
> alternative in the meantime:
> - install the perl module "Geo::Coder::US" (either through CPAN or at
> http://geocoder.us) & create a geocoder database from TIGER
> - create language plperlu in the database you want the geocoder function
> - create the following function, replacing "/path/to/geocoder.db" with
> the location of the geocoder database you created from TIGER
> CREATE OR REPLACE FUNCTION geocode(text) returns geometry as '
> use Geo::Coder::US;
> Geo::Coder::US->set_db("/path/to/geocoder.db");
> my <at> res = Geo::Coder::US->geocode($_[0]);
> return "SRID=4269;POINT(".$res[0]->{''long''}.
> " ".$res[0]->{''lat''}.")";
> ' LANGUAGE plperlu IMMUTABLE;
> Error checking (and all the rest of the fun stuff) is left as an
> exercise for the reader. That should be enough to get you started,
> though.
Here's a working script for Jeff's idea...
CREATE OR REPLACE FUNCTION geocode(text) returns geometry as $$
begin
return GeomFromEWKT(geocode_impl($1));
end;
$$ language plpgsql;
CREATE OR REPLACE FUNCTION geocode_impl(text) returns text as '
use Geo::Coder::US;
Geo::Coder::US->set_db("/data/spatial/north_america/usa/geocoder.db");
my @res = Geo::Coder::US->geocode($_[0]);
Also, I am using the tiger2005fe dataset, so if anyone needs it drop me a line
and I can save you some time.
