[postgis-users] points in polygon
Young Kim
youngkkim at gmail.com
Fri Mar 31 16:17:34 PST 2006
machine setup:
fast dual xeon processors
2 gig ram
slackware 10.2
postgresql 8.1.3
postgis 1.1.1
testing machine. nothing else is running.
VACUUM ANALYZE - most definitely.
On 3/31/06, Paul Ramsey <pramsey at refractions.net> wrote:
> You are right, 8000 is not a boatload, I did not know that was the
> number. Is it just me (I am terrible at reading explain analyze
> results) but is the spatial index condition being evaluated *before*
> the FIPS attribute condition?
> What is your PostGIS/PgSQL version? Have you run VACUUM ANALYZE on
> this database?
> P
> On 31-Mar-06, at 4:00 PM, Young Kim wrote:
> > here are explain outputs.
> > 1st line is "aggregate" because i'm just counting number of rows.
> > 8K points seem nothing to me.
> > People don't do spatial analysis on 8K+ points?
> > WHERE (polygon.fips = '0644000') AND point.the_geom &&
> > polygon.the_geom AND distance(polygon.the_geom, point.the_geom) <
> > 0.00000001;
> > Aggregate (cost=9.09..9.10 rows=1 width=4) (actual
> > time=32617.877..32617.877 rows=1 loops=1)
> > -> Nested Loop (cost=0.00..9.04 rows=17 width=4) (actual
> > time=960.179..32615.023 rows=3248 loops=1)
> > Join Filter: (distance("outer".the_geom, "inner".the_geom) <
> > 1e-08::double precision)
> > -> Index Scan using idx_polygon_fips on polygon
> > (cost=0.00..3.01 rows=1 width=9414) (actual time=0.012..0.015 rows=1
> > loops=1)
> > Index Cond: ((fips)::text = '0644000'::text)
> > -> Index Scan using idx_point_the_geom on point
> > (cost=0.00..6.01 rows=1 width=25) (actual time=62.287..17938.112
> > rows=7050 loops=1)
> > Index Cond: (point.the_geom && "outer".the_geom)
> > Filter: (point.the_geom && "outer".the_geom)
> > Total runtime: 32617.945 ms
> > WHERE (polygon.fips = '0644000') AND distance(polygon.the_geom,
> > point.the_geom) < 0.00000001;
> > Aggregate (cost=1060.81..1060.82 rows=1 width=4) (actual
> > time=18605.436..18605.437 rows=1 loops=1)
> > -> Nested Loop (cost=0.00..1053.59 rows=2888 width=4) (actual
> > time=10.252..18602.620 rows=3248 loops=1)
> > (cost=0.00..3.01 rows=1 width=9414) (actual time=0.016..0.020 rows=1
> > loops=1)
> > -> Seq Scan on point (cost=0.00..920.63 rows=8663 width=25)
> > (actual time=3.068..26.086 rows=8663 loops=1)
> > Total runtime: 18605.496 ms
> > polygon.the_geom AND CONTAINS(polygon.the_geom, point.the_geom);
> > time=164835.027..164835.027 rows=1 loops=1)
> > time=4182.576..164829.831 rows=3248 loops=1)
> > Join Filter: contains("outer".the_geom, "inner".the_geom)
> > loops=1)
> > (cost=0.00..6.01 rows=1 width=25) (actual time=62.540..18306.731
> > rows=7050 loops=1)
> > Total runtime: 164835.099 ms
> > WHERE (polygon.fips = '0644000') AND CONTAINS(polygon.the_geom,
> > point.the_geom);
> > Aggregate (cost=1039.15..1039.16 rows=1 width=4) (actual
> > time=146143.486..146143.487 rows=1 loops=1)
> > -> Nested Loop (cost=0.00..1031.93 rows=2888 width=4) (actual
> > time=64.431..146139.232 rows=3248 loops=1)
> > (cost=0.00..3.01 rows=1 width=9414) (actual time=0.016..0.021 rows=1
> > loops=1)
> > (actual time=0.283..38.307 rows=8663 loops=1)
> > Total runtime: 146143.551 ms
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
