[postgis-users] Collect problem
Daniel daniel.faivre at camptocamp.com
Tue May 2 02:46:02 PDT 2006
Hello,
I've used to proceed queries like:
SELECT collect(lga_geom) as buffer FROM lg_annee
WHERE lga_annee='2005' and lga_nat_cdn=2 and lga_var>-1 GROUP BY lga_annee;
With last versions of Postgis, such queries failed, even if I add tests
like:
WHERE lga_annee='2005' and lga_nat_cdn=2 and lga_var>-1 and lga_geom is
not null
and isvalid(lga_geom) and dimension(lga_geom)=2 GROUP BY lga_annee;
Errors reported are:
NOTICE:  Self-intersection
ERROR:  lwcollection_construct: mixed dimension geometries
Table lg_annee contain 2-dimension polygon geometries. The query worked
fine with older versions.
What can I do ?
Any idea ?
dF
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060502/0018b49e/attachment.vcf>
