[postgis-users] generating ocean
Arnaud Lesauvage
thewild at freesurf.fr
Tue May 2 06:44:05 PDT 2006
Christo Du Preez a écrit :
> I would still like to now how to generate oceans from my country
> boundaries. The problem using different datasets is that the data
> wouldn't be an exact match, layering it might produce gaps.
> Ill be happy with something like a box with a hole (country boundary) in
> as a result.
I believe this is what the Difference(geometry A, geometry B)
function does.
So you could use something like :
SELECT Difference(Expand(county_geometry, 100000), county_geometry))
FROM country_table;
It might use a lot of processing time / memory if the boundaries
are large though.
Arnaud
