[postgis-users] isvalid(the_geom)
Christo Du Preez
christo at mecola.com
Thu May 4 05:15:58 PDT 2006
Hi All,
I have used the isvalid(the_geom) in my queries but this makes a is very
slow. eg.
SELECT assvg(simplify(intersection(the_geom,
geomfromtext('POLYGON((15.900000000000002 -35.0, 15.900000000000002
-22.0, 33.3 -22.0, 33.3 -35.0, 15.900000000000002 -35.0))', -1)),
0.025), 0, 6) AS data
FROM table
WHERE the_geom && geomfromtext('POLYGON((15.900000000000002 -35.0,
15.900000000000002 -22.0, 33.3 -22.0, 33.3 -35.0, 15.900000000000002
-35.0))',-1)
AND distance(geomfromtext('POINT(24.6 -28.5)',-1),the_geom) <
10.860018416190647
AND isvalid(the_geom) = true
takes 4300ms
leaving out the 'AND isvalid(the_geom) = true' part
takes 2200ms
2200ms is still too slow but it's a big improvement already.
I thought of doing this:
ALTER TABLE table ADD COLUMN isvalid bool;
update table
set isvalid = isvalid(the_geom);
-- Index: table_btree_isvalid
-- DROP INDEX table_btree_isvalid;
CREATE INDEX table_btree_isvalid
ON table
USING btree
(isvalid);
vacuum verbose analyze table
on all my tables and will then change my queries too rather include 'WHERE isvalid = true'
Is this advisable???
Any thoughts on this?
It is s bit of a worry just leaving out rows that is not valid, I suppose the issue should be resolved right from the start, to rather fix the data in the first place.
The problem is that I have no idea how to, this is public domain data supplied by the government.
