[postgis-users] isvalid(the_geom)
Christo Du Preez
christo at mecola.com
Thu May 4 06:46:23 PDT 2006
Hi Markus,
Thanx for the advice. Out of the tools you mentioned, which one do you
prefer? Ease of use and functionality...
Markus Schaber wrote:
> Hi, Christo,
> Christo Du Preez wrote:
>> It is s bit of a worry just leaving out rows that is not valid, I
>> suppose the issue should be resolved right from the start, to rather fix
>> the data in the first place.
> Yes, that's right, expecially as validity tests can be so expensive.
>> The problem is that I have no idea how to, this is public domain data
>> supplied by the government.
> You will have to look into GIS tools like openJump, Java Conflation
> Suite, UDig or so - most of them have editing tools that allow for data
> validation and repairing.
> HTH,
> Markus
Kind Regards,
Christo Du Preez
Senior Software Engineer
Mecola IT
http://www.mecola.com
+27 [0]83 326 8087
