[postgis-users] liblwgeom.so.1.1
trevorw
trevorw at fanweb.ca
Thu May 4 10:28:42 PDT 2006
I've noted other responses on the list to this problem but seem unable
to solve it.
I'm attempting a source install on an Ubuntu breezy install on an AMD64
machine.
I successfully installed postresql 8.1.3 from source. I also installed
geos and proj from source.
My ld.so.conf file looks as follows:
/lib32
/usr/lib32
/usr/X11R6/lib32
/usr/lib/atlas
/usr/local/pgsql/lib
/usr/local/grass-6.1.cvs/lib
after updating for grass and pgsql I ran ldconfig.
I then downloaded postgis and put it in the contrib directory of my
source tree for posgresql as .../contrib/postgis
When running ./configure it finds proj, and geos, but has to be
explicitly told where pgsql is (/usr/local/pgsql/bin/pg_config).
It seems to compile and install without even, but following the setup
for a database I run into problems.
First I create plpgsql as instructed.
createlang plpgsql SPATIAL
Then I attempt load the PostGIS functions and objects using:
psql -d SPATIAL -f lwpostgis.sql
BUT then the following happens:
BEGIN
NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.1":
libgeos_c.so.1: cannot open shared object file: No such file or
directory ERROR: current transaction is aborted, commands ignored until
end of transaction block
Any suggestions about what I've done wrong would be helpful.
Thanks
T
Trevor Wiens
