[postgis-users] liblwgeom.so.1.1
trevorw
trevorw at fanweb.ca
Thu May 4 10:57:02 PDT 2006
I solved the problem. Somehow, /usr/local/lib wasn't in my ld.so.conf
and I hadn't noticed. I added it and re-ran ldconfig and everything
works.
T
On Thu, 4 May 2006 11:28:42 -0600
trevorw <trevorw at fanweb.ca> wrote:
> I've noted other responses on the list to this problem but seem unable
> to solve it.
> I'm attempting a source install on an Ubuntu breezy install on an
AMD64
> machine.
> I successfully installed postresql 8.1.3 from source. I also installed
> geos and proj from source.
> My ld.so.conf file looks as follows:
> /lib32
> /usr/lib32
> /usr/X11R6/lib32
> /usr/lib/atlas
> /usr/local/pgsql/lib
> /usr/local/grass-6.1.cvs/lib
> after updating for grass and pgsql I ran ldconfig.
> I then downloaded postgis and put it in the contrib directory of my
> source tree for posgresql as .../contrib/postgis
> When running ./configure it finds proj, and geos, but has to be
> explicitly told where pgsql is (/usr/local/pgsql/bin/pg_config).
> It seems to compile and install without even, but following the setup
> for a database I run into problems.
> First I create plpgsql as instructed.
> createlang plpgsql SPATIAL
> Then I attempt load the PostGIS functions and objects using:
> psql -d SPATIAL -f lwpostgis.sql
> BUT then the following happens:
> BEGIN
> NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> ERROR: could not load library
"/usr/local/pgsql/lib/liblwgeom.so.1.1":
> libgeos_c.so.1: cannot open shared object file: No such file or
> directory ERROR: current transaction is aborted, commands ignored
until
> end of transaction block
> Any suggestions about what I've done wrong would be helpful.
> Thanks
> T
> Trevor Wiens
> postgis-users mailing list
