[postgis-users] is it possible to dissolve boundaries in postgis?
strk at refractions.net
Fri May 5 01:53:59 PDT 2006
On Thu, May 04, 2006 at 05:41:41PM -0500, Nelson Guda wrote:
> Hi again,
> I think I figured out how to dissolve boundaries from an archived
> post. However, now that the new table is created I need to know how
> to "bless" the new geometry column. I tried creating a new geometry
> column and setting it equal to the newly created column, but it kept
> giving me the error "enforce_geotype_wkb_geometry" and I couldn't
> figure out a way around that.
> Can anyone help with this?
That means that you have mixed-type geometries in your result.
Probably Polygon, MultiPolygon or GeometryCollection.
Check that out and maybe create a column for each type.
--strk;
