[postgis-users] recursive query
Patricio Cifuentes Ithal
pcifuentes at siigsa.cl
Fri May 5 08:20:03 PDT 2006
hi...
add suplex query with extension....
example
WHERE SetSRID('BOX3D(".$ext[0]." ".$ext[1].",".$ext[2]."
".$ext[3].")'::box3d,-1) && the_geom ) as foo using unique gid using SRID=-1
only query result data viewer...
Ingeniero en Informática
Informática
SIIGSA
(56-2) 204 60 22
----- Original Message -----
From: "Benedetto Porfidia" <benedetto.porfidia at apat.it>
To: <postgis-users at postgis.refractions.net>
Sent: Friday, May 05, 2006 5:50 AM
Subject: [postgis-users] recursive query
> Hi all,
> I have a table of about 300.000 points and I want to check if the
> value of a field of each point is within the range of avg +/- stddev of
> the nearest points in certain radius.
> I tried with buffers and within or contains operators, but I can't
> figure out the right query.
> Can anyone help with this?
> thanks very much
> Benedetto
> postgis-users mailing list
