[postgis-users] GEOS and PostGIS
Shaun Kolomeitz shaun.kolomeitz at epa.qld.gov.au
Sun May 7 17:16:15 PDT 2006
Paul and Strk,
Many thanks for the assistance on getting GEOS (and PostGIS) to compile on Solaris 10.
The eventual solution was two fold -
Firstly I needed to add the /usr/local/lib into the system wide libraries using crle
(i.e. #t2k> crle -u -l /usr/local/lib). Secondly setting the correct PATH and LD_LIBRARY_PATH and LDFLAGS helped.
When I did this the correct make (gmake) was being used rather than the somewhat limited (?) Solaris make version.
Regards,
Shaun
___________________________
Disclaimer
This e-mail, including attachments if any, has originated from a Queensland government agency and may contain information that is confidential, or covered by legal professional privilege, and is intended for the named recipient(s) only.  If you have received this message in error, you are asked to inform the sender as quickly as possible and delete this message and any copies of this message from your computer system network.
Any form of disclosure, modification, distribution and/or publication of this e-mail, including attachments is prohibited.  Unless otherwise stated, this e-mail, including attachments represents the views of the sender and not the views of the Environmental Protection Agency.
Although this e-mail has been checked for the presence of computer viruses, the Environmental Protection Agency provides no warranty that all possible viruses have been detected and cleaned.  Any use of this e-mail could harm your computer system.
