[postgis-users] Problem with EndPoint and Touches Functions
Jonathan Aguero
jua130 at psu.edu
Mon May 8 10:52:48 PDT 2006
Dear List,
I created a point file with the EndPoint function from a line file. Then a
used the touches function to count how many line segments (from the line
file previously used to create the point file) touch each endpoint.
Surprisingly, some of the points have no line segments touching them. I am
guessing there is a problem with tolerances but how can I work it around?
Jonathan Aguero Valverde
Research Assistant and Ph.D. Candidate
Pennsylvania State University
The Pennsylvania Transportation Institute
201 Transportation Research Building
University Park, PA 16802
www.personal.psu.edu/jua130
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060508/fef2aff1/attachment.html>
