[postgis-users] Re: problem with BOX3D query
Eduardo Luís Garcia Escovar
eduardo.escovar at 3wt.com.br
Mon May 8 14:14:43 PDT 2006
From the PostGIS manual:
GeomFromText(text,[<srid>])
Makes a Geometry from WKT with the given SRID.
OGC SPEC 3.2.6.2 - option SRID is from the conformance suite
Is 'BOX3D(-111.80 33.30,-111.75 33.35)'::box3d a valid WKT?
Regards,
Eduardo
Randy George escreveu:
> Hi Patricio,
> Thank you very much! Mystery solved!
> I had copy/pasted Box3D from the PostGIS pdf manual and failed to notice
> that the apostrophe changes:
> pdf ’ = hex 92 instead of hex 27 '
> once I change to hex 27 apostrophe everything works as expected.
> >From pdf manual:
> SELECT
> AsText(GEOM) AS GEOM
> FROM ROADS_GEOM
> WHERE
> GEOM && GeomFromText(’BOX3D(191232 243117,191232 243119)’::box3d,-1);
> Note the apostrophe!
> SELECT the_geom FROM streets
> WHERE the_geom && SetSRID(’BOX3D(-111.80 33.30,-111.75 33.35)’::box3d,4269);
> will not work
> but
> WHERE the_geom && SetSRID('BOX3D(-111.80 33.30,-111.75 33.35)'::box3d,4269);
> will work as expected.
> Interestingly -
> WHERE the_geom && GeomFromText('BOX3D(-111.80 33.30,-111.75
> Produces response:
> ERROR: function geomfromtext(box3d, integer) does not exist
> HINT: No function matches the given name and argument types. You may need
> to add explicit type casts.
> So manual may need to be updated?
> Thanks
> Randy
