[postgis-users] decode geometry
Paul Ramsey
pramsey at refractions.net
Tue May 9 13:18:19 PDT 2006
Geoserver has had some success in using encode(asbinary
(the_geom),'base64') as a means of encoding geometries in a 7-bit
clean wrapper for WKB. Spares one having to futze around with binary
cursors. Then you use a base64 decode on your client to get the byte
array and then write a wkb decoder in your client. Fun fun.
Note that this is hardly a "solution" to your problem, since even if
you reduce your overhead by 50%, Murphy's Law says there will still
be the occasional geometry large enough to break your application.
P
On May 9, 2006, at 8:11 AM, Bruce Rindahl wrote:
> The project PgArc uses Visual Basic to parse WKT format into a
> shapefile for ArcGIS so this would not help. If you are successful
> in decoding WKB please post and I will try to include it into PgArc.
> Thanks
> Bruce Rindahl
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of Miguel de la
> Fuente
> Sent: Tuesday, May 09, 2006 8:53 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] decode geometry
> Hello, we're trying to view PostGis data from Visual Basic using a
> binary cursor
> (trough ODBC) because features in some tables has too many points
> and the
> function astext() returns strings unacceptably large (about 400
> KBytes).We
> think that receiving it as binary will decrease size and increase
> performance. Does anybody know how can we decode geometry data from
> wkb or
> any documentation about it?
> Thanks.
> postgis-users mailing list
