[postgis-users] postgis.pdf
strk at refractions.net strk at refractions.net
Wed May 10 06:41:35 PDT 2006
On Wed, May 10, 2006 at 02:30:38PM +0200, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net wrote:
> > It seems we're having some problems widh pdf generation.
> > Doesn't seem related to postgis itself, but to external
> > dependencies. If anyone can test running the 'make postgis.pdf'
> > rule under the doc/ dir of any 1.x postgis version we
> > can gather some informations on what's going on.
> On CVS HEAD:
> -> make postgis.pdf
> /usr/bin/xsltproc --param section.autolabel 1 --param
> section.label.includes.component.label 1 --param chunk.section.depth 0  \
>                 --output postgis.fo \
>                 /usr/share/xml/docbook/stylesheet/nwalsh/fo/docbook.xsl \
>                 postgis-out.xml
> Making portrait pages on USletter paper (8.5inx11in)
> postgis.fo
> make: postgis.fo: Command not found
> make: *** [postgis.pdf] Error 127
> {2} ->
That's because you don't meet the requirements.
I've added a README file under doc/ listing them.
--strk;
PS: note, rule is "$(PDFXMLTEX) postgis.fo", so
you only miss the pdfxmltex part.
