[postgis-users] Interesting Datum Conversion Issue
James G Wilkinson
jgw at alpinegeophysics.com
Thu May 11 15:31:30 PDT 2006
A situation has occurred that I am having difficulty getting my hands
around.
I have a single point with the following attributes:
lon = -115.10101
lat = 36.15526
PROJ4 entry in SPATIAL_REF_SYS
+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs
In ARC/Info, when I project this point to the following:
projection: LAMBERT
datum: NONE
units: meters
spheroid: sphere
1st parallel: 33.0
2nd parallel: 45.0
central meridian: -118.0
latitude of origin: 37.0
false easting: 0.0
false northing: 0.0
I get back a point at y-coord = -89372 m.
The above projection is entered into my SPATIAL_REF_SYS table
with the following PROJ4 parameters (SRID=888889):
+proj=lcc +lat_1=33.0 +lat_2=45.0 +lat_0=37.0 +lon_0=-118.0 +x_0=0
+y_0=0 +a=6370997.0 +b=6370997.0 +units=m
Now with PostgreSQL v.7.4.8, PostGIS v.0.9.1, and PROJ4 v.4.4.7,
this same point using SELECT Y ( TRANSFORM (the_geom, 888889) ) FROM
spatial.pt_test
returns -89074 (which is close enough for my work.....for now).
When I migrated to PostgreSQL v.8.1.3, PostGIS v.1.1.2, and PROJ4 v.4.4.9,
my SELECT returns -109641 (!! and this is what baffles me !!).
Any help that folks can lend will be greatly appreciated.
Regards,
Jim
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060511/1558a48f/attachment.html>
