[postgis-users] Divide 1 Polygon into 2 polygons with a linestring
Martin Davis
mbdavis at VividSolutions.com
Fri May 12 14:05:40 PDT 2006
Yep, absolutely. In fact, that's probably the only situation in which you could reasonably apply the "add a box to the line" technique.
I'm still hopeful I'll be able to provide a generic solution to this problem in JTS - I know how to do it, and have all the hard code written - it's just finding time to turn it into a usable API.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc. www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Stephen Woodbridge
> Sent: May 12, 2006 12:20 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Divide 1 Polygon into 2 polygons
> with a linestring
> Martin, Baris,
> It might be slightly simpler to do if you enforce the constraint that
> the linestring end points are OUTSIDE the bbox of the
> polygon. In this
> case you can intersect the linestring with the bbox of the
> polygon (or
> slightly expanded bbox) the construct a polygon based on the
> intersection points, the linestring intersected with the bbox
> and half
> the bbox based on the intersection. Once you have this,
> intersection and
> difference of the constructed polygon and the original
> polygon will give
> you the two pieces you want.
> Yes, this is a little bit of work by it is well defined, and fairly
> straight forward and could be all done in a plpgsql stored procedure.
> -Steve W
> Martin Davis wrote:
> > Currently there's no code in JTS which will do this, and not really
> > any
> > sequence of operations which will perform this easily. The obvious
> > thing to try is to extend the linestring far enough to be
> able to "bend
> > it around" into a polygon, which you can then use to cut the other
> > polygon (via intersection and difference). But this is
> awkward and not
> > a general solution.
> > There is a general solution to this, but it requires a more fully
> > developed set of topological classes than are currently in JTS.
> > This is probably the most-requested enhancement for JTS.
> Hopefully we
> > will get time & funding sometime soon to implement this.
> > *Martin Davis, Senior Technical Architect*
> > *Vivid Solutions Inc. /www.vividsolutions.com/*
> > /Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> > Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046/
> > *From:* postgis-users-bounces at postgis.refractions.net
> *On Behalf Of
> > *Baris YILMAZ
> > *Sent:* May 12, 2006 11:00 AM
> > *To:* PostGIS Users Discussion
> > *Subject:* [postgis-users] Divide 1 Polygon into 2
> polygons with a
> > linestring
> > Hi,
> > I have a problem. I have a polygon and a Linestring.
> The linestring
> > enters at one point the polygon and leaves at another. In other
> > words, it goes through the polygon. I need to divide the polygon
> > into two pieces, one right to the linestring and one left.
> > Is there any method doing this? Can anyone help me? I
> searched also
> > in JTS package but I couldn't find anything.
> > I 'll appreciate your help.
> > Best Regards
> > Baris
> > Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone
> calls. Great
> > rates starting at 1¢/min.
> <http://us.rd.yahoo.com/mail_us/taglines/postman7/> *http://us.rd.yahoo.
> > com/evt=39666/*http://messenger.yahoo.com>
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
