[postgis-users] calculating area from geometry intersections
Nelson Guda
nelsong at mail.utexas.edu
Wed May 17 12:42:27 PDT 2006
Hi all,
I need to design a query that will return take one or more polygons
from one table (for example, county shapes) and return data from the
intersection of those polygons with polygons from another table.
More specifically, I have one table that is polygons of roadless
forest areas (no relation to county boundaries), and I would like to
assemble a query that will tell me within a given county:
1) the names of the roadless areas that intersect or fall within the
county, and
2) how many acres of each type of roadless area is within the county
(the roadless area polygons are divided into several different
categories)
The counties and roadless areas are the same SRID (NAD27). I'm not
sure how to go about building this query, though I imagine it starts
with creating a temp table with an intersection command.
I've also had problems calculating area with the postgis command, but
I don't know what the problem is. The number that is always way too
small. An example of a command I've used is:
select sum(area(wkb_geometry))/10000 AS hectares from irasda where
state='WA'
Any help would be greatly appreciated.
Many thanks,
nelson
