[postgis-users] Postgis 1.1.2 installation problems on Redhat 9
Johan V jvhoppli at gmail.com
Thu May 18 00:08:17 PDT 2006
I installed postgresql 8.0.6-1PGDG (i686), geos-1.0-2 (i386) and proj
4.4.7-1 (i386) with rpm packages. Now i want to install postgis 1.1.2
with the default configure, make and make install instruction put i
get some errors, this is the output i get (sorry for the dutch words):
[root at 192 postgis]#
/home/postgis/postgresql-8.0.6/contrib/postgis/configure
--with-geos-src=/home/postgis/geos-1.0/source/
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether ln -s works... yes
checking for iconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for pg_config... /usr/bin/pg_config
checking for geos-config... /usr/bin/geos-config
checking for proj... /usr/local/bin/proj
checking for flex... /usr/bin/flex
checking for dllwrap... no
checking for dlltool... no
checking for yacc... /usr/bin/yacc
checking for perl... /usr/bin/perl
checking for xsltproc... /usr/bin/xsltproc
checking for pdfxmltex... /usr/bin/pdfxmltex
checking for jw... /usr/bin/jw
checking which template to use... linux
configure: creating ./config.status
config.status: creating Makefile.config
config.status: creating config.h
config.status: config.h is unchanged
 SUMMARY
 HOST_OS: linux-gnu
   PGSQL: /usr/bin/pg_config
    GEOS: /usr/bin/geos-config
    PROJ: dir=/usr/local
   ICONV: 1
 PORTNAME: linux
   PREFIX: /usr
  EPREFIX: ${prefix}
      DOC: /usr/share/doc/postgresql/contrib
     DATA: /usr/share/pgsql/contrib
      MAN: /usr/share/man
      BIN: /usr/bin
      EXT: /usr/lib/pgsql (\$$libdir)
[root at 192 postgis]# make
make -C lwgeom
make[1]: Binnengaan van map
`/home/postgis/postgresql-8.0.6/contrib/postgis/lwgeom'
sh ../geos_version.sh /usr > postgis_geos_version.h
g++ -I/usr/include  -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS   -c -o
lwgeom_geos_wrapper.o lwgeom_geos_wrapper.cpp
lwgeom_geos_wrapper.cpp:11:23: fout: geos/geom.h: Onbekend bestand of map
lwgeom_geos_wrapper.cpp:12:23: fout: geos/util.h: Onbekend bestand of map
lwgeom_geos_wrapper.cpp:22: fout: 'geos' is not a namespace-name
lwgeom_geos_wrapper.cpp:22: fout: expected namespace-name before ';' token
lwgeom_geos_wrapper.cpp:98: let op: 'GEOSrelate' krijgt beginwaarde en
is als 'extern' gedeclareerd
lwgeom_geos_wrapper.cpp:98: fout: 'Geometry' was not declared in this scope
lwgeom_geos_wrapper.cpp:98: fout: 'g1' was not declared in this scope
lwgeom_geos_wrapper.cpp:98: fout: 'g2' was not declared in this scope
lwgeom_geos_wrapper.cpp:98: fout: initializer expression list treated
as compound expression
lwgeom_geos_wrapper.cpp:102: let op: 'GEOSSetSRID' krijgt beginwaarde
en is als 'extern' gedeclareerd
lwgeom_geos_wrapper.cpp:1779: fout: redefinition of 'bool GEOSHasZ'
lwgeom_geos_wrapper.cpp:161: fout: 'bool GEOSHasZ' previously defined here
lwgeom_geos_wrapper.cpp:1779: fout: 'Geometry' was not declared in this scope
lwgeom_geos_wrapper.cpp:1779: fout: 'g' was not declared in this scope
lwgeom_geos_wrapper.cpp:1794: fout: expected constructor, destructor,
or type conversion before '*' token
lwgeom_geos_wrapper.cpp:1828: fout: expected constructor, destructor,
make[1]: *** [lwgeom_geos_wrapper.o] Fout 1
make[1]: Weggaan uit map `/home/postgis/postgresql-8.0.6/contrib/postgis/lwgeom'
make: *** [liblwgeom] Fout 2
Like you see, I even put the postgis directory in the contrib
directory of the postgresql source. As far as I can understand this
error is that the "make" instruction can't find the .h files of geos,
but how do i point the make to the correct directory of those header
files. I tried it with "--with-geos-src" but that wasn't it.
Thx on advance,
Johan.
