[postgis-users] How can I convert a geometry column to polygons
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 19 07:03:12 PDT 2006
Oh, if you really want the intersection of the polygons, then you will
need to deal with results that are not always a polygon, because the
intersection of two polygons does not have to be a polygon, it can in
fact be a point if the two polygons touch at a vertex or a linestring if
the share a common edge(s).
I this case you probably need to write a set returning function the
allows you to scan the results and return just the polygons.
I would probably be a nice function to add to PostGIS. Something like
<set_of_geom_type> = extract_geom(<collection>, <geom_type>);
or something similar.
-Steve
Stephen Woodbridge wrote:
> Brent Wood wrote:
>> I have a table with a polygon geometry table. I want to select a
>> subset of the
>> polygons via an area, which is defined by another polygon.
>> I can sort of get the result using intersection() but the result is a
>> set of
>> geometries, not polygons.
>> How can I turn these into polygons?
> What do you want to get back from the polygon table is an polygon there
> partially intersects your selection polygon?
> If you want all of the partials, then
> select * from polygon_table
> where
> the_geom && select_polygon and
> intersects(the_geom, select_polygon);
> you can replace "select_polygon" with a sub-select like Eric suggested.
> If you only want the polygons that are totally within the select polygon
> then change the intersects() to within()
> -Steve W.
> postgis-users mailing list
