[postgis-users] Length, distance, area using SRID 6326
Paul Ramsey pramsey at refractions.net
Sat May 20 20:57:36 PDT 2006
There is no help to give, you have all the pieces in front of you.
If your reference system is in spherical coordinates and you do not
want to do a transform() to a planar system, use the _sphere or
_spheroid functions.  _sphere is faster than _spheroid, but less
accurate -- you may find it is well within the tolerances you need
however.  Spheroid calculations are very expensive, nothing to be
done about that (difference between a converging set of differential
equations and a simple trig formula).
P.
On May 20, 2006, at 2:18 PM, Fermín Pieri wrote:
> Hi, I am using SRID 6326 as the spatial reference id of the geom
> column. But
> when i try to use length, distance and area functions, the results
> are not
> what i expect (of course, using spherical calcultations) Any idea?
> Opengis
> specification says that this functions return the result using the
> SRID of
> the geom column. Why postgis include distance_sphere,
> length_spheroid, etc.?
> I tried length_spheroid and the result is what i need but it takes
> a long
> processing time. I will appreciate somebody's help
> Thanks
> Fermin
> postgis-users mailing list
