[postgis-users] postgis-users Digest, Vol 43, Issue 21
Fermín Pieri
fpieri at faster.com.uy
Sun May 21 14:38:45 PDT 2006
Paul, thanks for your reply.
I saw the function distance_sphere but not the length_sphere.
Is there a function called length_sphere?
Thanks
Fermín
-----Mensaje original-----
De: orkun [mailto:temiz at deprem.gov.tr]
Enviado el: Sunday, May 21, 2006 18:20
Para: postgis-users at postgis.refractions.net
Asunto: [postgis-users] postgis-users Digest, Vol 43, Issue 21
Send postgis-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://postgis.refractions.net/mailman/listinfo/postgis-users
or, via email, send a message with subject or body 'help' to
postgis-users-request at postgis.refractions.net
You can reach the person managing the list at
postgis-users-owner at postgis.refractions.net
When replying, please edit your Subject line so it is more specific than
"Re: Contents of postgis-users digest..."
Today's Topics:
1. Length, distance, area using SRID 6326 (Ferm?n Pieri)
2. Re: Length, distance, area using SRID 6326 (Paul Ramsey)
3. polygon width (orkun)
4. Re: polygon width (Paul Ramsey)
Message: 1
Date: Sat, 20 May 2006 18:18:23 -0300
Subject: [postgis-users] Length, distance, area using SRID 6326
To: "'postgis-users at postgis.refractions.net'"
<postgis-users at postgis.refractions.net>
Message-ID: <7EFC8543031AD911A7940004AC96C65E02011C at NETCOM01>
Content-Type: text/plain; charset="iso-8859-1"
Hi, I am using SRID 6326 as the spatial reference id of the geom column. But
when i try to use length, distance and area functions, the results are not
what i expect (of course, using spherical calcultations) Any idea? Opengis
specification says that this functions return the result using the SRID of
the geom column. Why postgis include distance_sphere, length_spheroid, etc.?
I tried length_spheroid and the result is what i need but it takes a long
processing time. I will appreciate somebody's help
Thanks
Fermin
Message: 2
Date: Sat, 20 May 2006 20:57:36 -0700
Subject: Re: [postgis-users] Length, distance, area using SRID 6326
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID: <616D36E8-09BC-4ECC-BD28-5BE62CEBAF43 at refractions.net>
Content-Type: text/plain; charset=ISO-8859-1; delsp=yes; format=flowed
There is no help to give, you have all the pieces in front of you. If your
reference system is in spherical coordinates and you do not want to do a
transform() to a planar system, use the _sphere or _spheroid functions.
_sphere is faster than _spheroid, but less accurate -- you may find it is
well within the tolerances you need however. Spheroid calculations are very
expensive, nothing to be done about that (difference between a converging
set of differential equations and a simple trig formula).
P.
> column. But
> are not
> Opengis
> SRID of
> a long
> Thanks
> Fermin
> postgis-users mailing list postgis-users at postgis.refractions.net
Message: 3
Date: Sun, 21 May 2006 14:21:19 +0300
Subject: [postgis-users] polygon width
To: postgis-users at postgis.refractions.net
Message-ID: <44704D2F.60502 at deprem.gov.tr>
Content-Type: text/plain; charset=ISO-8859-9; format=flowed
hello
I want to know how I can calculate widths of polygons via postgis command
regards
Ahmet Temiz
Jeoloji Müh.
Afet Ýþleri Genel Müdürlüðü
Deprem Araþtýrma Dairesi
Tel: (312) 287 89 51 veya (312) 287 26 80/1547
Faks: (312) 287 89 51
E. Posta: temiz at deprem.gov.tr
www.deprem.gov.tr
Ahmet Temiz
Geological Eng.
General Directorate of Disaster Affairs
Earthquake Research Department
Phone: +90 (312) 287 89 51 or (312) 287 26 80/1547
Fax: +90 (312) 287 89 51
E. Mail: temiz at deprem.gov.tr
www.deprem.gov.tr
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
Message: 4
Date: Sun, 21 May 2006 09:17:46 -0700
Subject: Re: [postgis-users] polygon width
Message-ID: <1167274E-80AA-4E28-961F-617F6347FB20 at refractions.net>
Content-Type: text/plain; charset=UTF-8; delsp=yes; format=flowed
What is the "width" of a polygon? Maximum straight line diameter? What if
it crosses a hole? Diameter along a particular axis or direction?
***Say, polygons are similar to rectangles. I want to know the values of
***their short sides.
***these polygon don't have any hole in them.
regards
Ahmet Temiz
P
On 21-May-06, at 4:21 AM, orkun wrote:
> hello
> command
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet İşleri Genel Müdürlüğü
> Deprem Araştırma Dairesi
> www.deprem.gov.tr
> Ahmet Temiz
> Geological Eng.
> www.deprem.gov.tr
End of postgis-users Digest, Vol 43, Issue 21
