[postgis-users] Multiple table join - mapserver
Patricio Cifuentes Ithal
pcifuentes at siigsa.cl
Mon May 22 07:24:21 PDT 2006
hi...
add suplex query with extension....
example
WHERE SetSRID('BOX3D(".$ext[0]." ".$ext[1].",".$ext[2]."
".$ext[3].")'::box3d,-1) && the_geom ) as foo using unique gid using SRID=-1
only query result data viewer...
Ingeniero en Informática
Informática
SIIGSA
(56-2) 204 60 22
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, May 19, 2006 8:01 PM
Subject: Re: [postgis-users] Multiple table join - mapserver
> I am surprised it is eating up memory, but not surprised it is slow,
> it is possible you are getting a bad plan... make sure you have run
> VACUUM ANALYZE.
> You could try:
> DATA "the_geom FROM (SELECT akmon_pt.the_geom AS the_geom ,akmon_pt.maid
> AS maid,akmon_pt.locid AS locid FROM akmon_pt,i5dbxma , i5maxat where
> akmon.the_geom && !BOX! and akmon_pt.maid=i5dbxma.maid and
> i5maxat.maid=i5dbxma.maid and i5maxat.atid=1 and i5dbxma.fyear>=1992
> and i5dbxma.lyear<=2005 and
> i5dbxma.spp=2 and i5dbxma.esu=-363155345) AS foo USING UNIQUE locid
> USING SRID=-1"
> I am not sure how robust the DATA parsing method is, but the !BOX!
> hack exists as a way of ensuring Mapserver creates a SQL query
> exactly the way you expect, rather than tacking the box on the end
> and hoping the PgSQL planner can resolve it into something efficient
> (usually, it can).
> Paul
> On May 19, 2006, at 1:49 PM, Greg Robillard wrote:
> > I'm using a subselect in my mapfile that uses three tables:
> > akmon_pt.maid=i5dbxma.maid and i5maxat.maid=i5dbxma.maid and
> > i5maxat.atid=1 and i5dbxma.fyear>=1992 and i5dbxma.lyear<=2005 and
> > USING SRID=-1"
> > It causes postgres to eat up all available memory on the machine. If I
> > execute the above in psql, the record returns instantly. If I
> > attempt to
> > join only two tables, Mapserver works fine.
> > Is this a known limitation?
> > Best,
> > Greg Robillard
> > Database Developer
> > State of the Salmon
> > greg at ecotrust.org
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
