[postgis-users] Why can I see my attribute data in Udig and not using SQL-commands ?
Paul Ramsey pramsey at refractions.net
Tue May 23 07:54:34 PDT 2006
Because the geometries are very large, so when psql tries to print
them to the screen, it creates a lot of white space first.  Try
"select count(*) from mytable".  If it is > 0 then you do have data.
On May 23, 2006, at 7:26 AM, Steven De Vriendt wrote:
> Hi List,
> I've imported a shapefile in a postgis table using shp2pgsql.
> When I explore my data in Udig I can see my attribute data for the
> corresponding features, yet, when I use the SQL commands in PostgreSQL
> I get a blank screen...
> I can only see the header of my columns, not the data itself ? How
> come ??
> postgis-users mailing list
