[postgis-users] Google Earth/PostGIS integration
Craig Miller
craig.miller at spatialminds.com
Tue May 23 15:29:54 PDT 2006
David,
I saw this press release from cubeworx although I haven't researched or used
the product personally.
http://www.cubewerx.com/main/about_us/news/Google.html
--Craig
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of TECHER
David
Sent: Tuesday, May 23, 2006 1:56 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Google Earth/PostGIS integration
Hi
Did U have some interesting URL ( WMS->GE gateways) to give us for that.
Thanks
--david;
Craig Miller a écrit :
There are a couple of WMS->GE gateways. You could use one of those to load
the GE basemap as a WMS layer, then put the PostGIS data on top of it.
--Craig
-----Original Message-----
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ezequias
Rodrigues da Rocha
Sent: Tuesday, May 23, 2006 10:20 AM
Sure it is nice. I just thought it could be more easy do a postgis
connection with Google Maps. But how to connect (or just see) this bases ?
I have a desktopGIS with me and would like how to load a layer on Google.
Regards
Ezequias
Brian Timoney escreveu:
Jim:
With time a little short these days, I'll simply sketch out a few key
points--
1) The viewbox parameters for Google Earth (bbox, tilt, heading,
range, etc.) can be read by a server script (PHP, ASP, CFM, etc.) via
a Network Links layer in GE.
2) Now that you have a handle on where the viewer is looking, how far
they're zoomed in, etc., you can craft SQL queries to do perform
geoprocessing operations (e.g. clipping), etc. Again, using
server-side scripting, you can then query your PostGIS db on the back-end.
3) The Geometry specifications for Googles KML (Keyhole Markup
Language) are very similar to the OGC's GML standard. So pulling
geometry out of PostGIS using the 'AsGML(the_geom)' function gets you
90% home in terms of converting query responses back into KML.
4) Applying the appropriate MIME types to the KML you send out from
the server will ensure that the receiving browser knows to shuttle the
response to the GE interface.
5) Using GE's internal web browser (Windows only), is a handy way of
keeping the user in the general "environment" even though technically
the bulk of the data transaction is taking place between web browser and
server.
Hope this is helpful,
Brian
The Timoney Group
518 17th Street
Suite 430
Denver, CO 80206
Ph: (303) 929-3722
Fax: (303) 571-4304
www.thetimoneygroup.com
The Timoney Group
518 17th Street
Suite 430
Denver, CO 80206
Ph: (303) 929-3722
Fax: (303) 571-4304
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Ezequias Rodrigues da Rocha
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060523/198800ac/attachment.html>
