[postgis-users] dfx on PostGIS
Eduardo Luís Garcia Escovar eduardo.escovar at 3wt.com.br
Wed May 24 11:57:07 PDT 2006
It is possible to obtain georeferenced data from a dxf file?
After taking a look at OGR supported formats
(http://ogr.maptools.org/ogr_formats.html), I thought that dxf
georreferencing was not possible.
Thanks is advance,
Eduardo
René F. Viancos S. escreveu:
> Hi Ezequias, currently i'm working with a command line dxf to shp
> converter (dxf2shp.exe and shp2dxf.exe), and then i load the shapefile
> in postgis. i'm interested in your plug'in
> Regards
> 2006/5/24, Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br
> <mailto:ezequias at recife.pe.gov.br>>:
>     Hi list,
>     Just for announce if someone is interested. If you have a large
>     amount of *dxf* file you can put it all on PostGIS using OpenJUMP
>     and a plugin.
>     If anyone is interested please contact me in privately.
>     Regards ...
