[postgis-users] Getting GID value from an Insert query
Bruce Rindahl
rindahl at lrcwe.com
Thu May 25 10:13:48 PDT 2006
This is probably a straight SQL issue but hopefully someone can help.
I am running an insert query into a PostGIS/PostgeSql database. The query
runs fine into a table with a unique GID value. I then need to get that row
id back to display in a web display. How can I get the GID from the insert
query I just ran?
The query is:
insert into dwr_gis (the_geom) values (GeomFromText('POLYGON((-2.29
1510.00,-1586.66 1851.53,.....,-2.29 1510.00))',26913))
and the result is:
Query returned successfully: 1 rows affected, 47 ms execution time.
Thanks!
Bruce Rindahl
