[postgis-users] Problem with transformation (NAD80 to SPCS)
Brent Pedersen bpederse at nature.Berkeley.EDU
Fri May 26 12:57:08 PDT 2006
hi, i just did a similar thing and make the same mistake...
POINT takes x y you have y x
try:
select AsText(Transform(GeometryFromText('POINT(-88.051944 41.783)',
4269), 99999));
-brent
On Fri, 26 May 2006, CYW wrote:
> Hi all,
> I need to project latitude and longitude points in NAD83 to SPCS. The
> projection as described in shapefiles prj file is as below:
> PROJCS["NAD_1983_StatePlane_Illinois_East_FIPS_1201_Feet",GEOGCS["GCS_North_
> American_1983",DATUM["D_North_American_1983"
> ,SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT[
> "Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["F
> alse_Easting",984250.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_M
> eridian",-88.33333333333333],PARAMETER["Scale_Factor",0.999975],PARAMETER["L
> atitude_Of_Origin",36.66666666666666],UNIT["Foot_US",0.3048006096012192]]
> This projection is not in the spatial_ref_sys table, the one that is close
> to it is SRID 26791, but it is in meter unit. So I creates a projection and
> assigned it an SRID 99999.
> I tested it with a lat-long data point in NAD83 (SRID=4269), below is the
> sql I used:
> select AsText(Transform(GeometryFromText('POINT(41.783333 -88.051944)',
> 4269), 99999));
> The response I got, which is wrong, is:
> POINT(1531185.06921148 -46594510.0726977)
> Obviously, I am wrong somewhere.
> Thanks in advance for any advice.
> _CYW_
> Below is the full screen capture showing the projection definition and
> transformation sql:
> mydb=#   select *  from spatial_ref_sys where  "srid"=99999;
> srid  | auth_name | auth_srid |     srtext   | proj4text
> 99999 | EPSG      |     99999 |
> American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,2
> 98.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PR
> OJECTION["Transverse_Mercator"],PARAMETER["False_Easting",984250.0],PARAMETE
> R["False_Northing",0.0],PARAMETER["Central_Meridian",-88.33333333333333],PAR
> AMETER["Scale_Factor",0.999975],PARAMETER["Latitude_Of_Origin",36.6666666666
> 6666],UNIT["Foot_US",0.3048006096012192]] | +proj=tmerc
> +lat_0=36.66666666666666 +lon_0=-88.33333333333333 +k=0.999975 +x_0=300000
> +y_0=0 +ellps=GRS80 +units=us-ft +no_defs
> (1 row)
> mydb=# select AsText(Transform(GeometryFromText('POINT(41.783333
> -88.051944)', 4269), 99999));
>                  astext
> (1 row)
> postgis-users mailing list
