[postgis-users] newbie questions
Benedetto Porfidia
benedetto.porfidia at apat.it
Mon May 29 09:25:17 PDT 2006
Stephen Woodbridge wrote:
> Benedetto Porfidia wrote:
>> Hi all,
>> I have 300000 points table and I want to calculate for each point the
>> average of a field of other points within 4 km radius.
>> I tried:
>> SELECT a.gid AS id, avg(b.anom267) AS avg, stddev(b.anom267) AS stddev
>> FROM provino a, provino b
>> WHERE distance(a.the_geom, b.the_geom) < 4000::double precision
>> GROUP BY a.gid;
>> First problem is about performance (it takes 15 hours) and the second
>> is that it returns results only for points that have neighbours
>> within the search radius. how can I tell postgis to put avg=anom267
>> and stddev = 0 for all isolated points?
>> which is the right sintax to perform the query on 3dboxes to speed up
>> (I hope)?
>> thanx in advance
>> Benedetto
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Benedetto,
> Try this query
> WHERE expand(a.the_geom, 4000) && b.the_geom and
> GROUP BY a.gid;
> The additional where cause filters points that are only within 4000 of
> other points before doing the distance() calculation.
> -Steve
WOW
thanks Steve.
it takes 158 seconds returning all records!!
Benedetto
