[postgis-users] pgrouting 0.7 and a*
Ville Antti Ensio Leinonen levian00 at students.oamk.fi
Sun Nov 5 09:16:13 PST 2006
Hi. Im working with routing. I allready have tryed with pgdijsktra module
and that worked somewhat right, now i found pgrouting 0.9.7 module. I got
dijkstra to works sameway as in pgdijsktra, but i cant find any howto or
tutorial to get A* work.
for dijkstra i have
l table with data
l.edges has id,source,targer,cost,reverse_cost
l.vertices has id,the_geom
works fine after little modification to _internal_id() function, and
actually looks like pgrouting works better that pgdijkstra when using
dijsktra.
Now what i need to do to get A* work, i assume that i need x1,x2,y1,y2
columns to l.edges table? but what data and how i populate those values?
maybe something to do with long/lat?
shortest_astar_path_as_geometry('l', source_id, target_id, delta);
And what is delta, README.INSTALL file dosen't talk to me.
Thanks You for help
  --	Ville Leinonen		 --
