[postgis-users] PostGIS Solaris problem
Svonja, Elvis Elvis.Svonja at sensis.com.au
Sun Nov 5 19:00:42 PST 2006
Thanks Andrew.
As you suggested, I tried adding "/usr/sfw/bin" at the front of the
PATH, as well as "/usr/sfw/lib" to the LD_LIBRARY_PATH.
I also made sure I have the Bison latest version for Solaris 10
installed, but no luck.  I keep getting the "broken pipe" error, as
shown below.
Is there a specific version of PostGIS that is recommended for Solaris
10 SPARC ?
ERROR DETAILS:
bison -y -vd -p lwg_parse_yy wktparse.y
gmake[2]: *** [wktparse.tab.c] Broken Pipe
gmake[2]: Leaving directory `/da01/postgresql/gis/postgis-1.1.4/lwgeom'
gmake[1]: *** [liblwgeom] Error 2
gmake[1]: Leaving directory `/da01/postgresql/gis/postgis-1.1.4'
*** Error code 2
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Andrew Seales
Sent: Friday, 3 November 2006 9:34 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS Solaris problem
Andrew Seales wrote:
> Svonja, Elvis wrote:
>> I have used GNU Make, and ensured the original one is removed from
the
>> PATH. I also installed bison-1.875d
<ftp://ftp.sunfreeware.com/pub/freeware/intel/10/bison-1.875d-sol10-inte
>> l-local.gz> ,
>> However I'm now getting another Broken Pipe message with executing
the
>> following Bison call:
Sorry, forgot to mention you'll probably need to do 'export
LD_LIBRARY_PATH=/usr/sfw/lib:$LD_LIBRARY_PATH' as well.
Andrew Seales
EDINA                   tel: +44 (0) 131 651 1430
Edinburgh University    fax: +44 (0) 131 650 3308
Main Library Building   url: http://edina.ac.uk
George Square           email: andrew.seales at ed.ac.uk
Edinburgh EH8 9LJ
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Sensis. Australia's leading information resource.
Making complex lives simpler by helping you find, buy and sell.
www.about.sensis.com.au
www.sensis.com.au
www.yellow.com.au
www.whitepages.com.au
www.citysearch.com.au
www.whereis.com.au
www.gostay.com.au
www.justlisted.com.au
www.linkme.com.au
www.telstra.com.au
www.tradingpost.com.au
www.universalpublishers.com.au
www.invizage.com.au
Sensis cares for the environment - think before you print.
This email and any attachments are intended only for the use of the recipient and may be confidential and/or legally privileged.
Sensis Pty Ltd disclaims liability for any errors, omissions, viruses, loss and/or damage arising from using, opening or transmitting this email.
If you are not the intended recipient you must not use, interfere with, disclose, copy or retain this email and you should notify the sender immediately by return email or by contacting Sensis Pty Ltd by telephone on [+61 3 8653 5000]
