[postgis-users] Re: ver 1.1.5 configure fails on Ubuntu
strk at refractions.net
Fri Nov 10 06:25:39 PST 2006
On Thu, Nov 09, 2006 at 09:23:20PM -0500, Steven Johnson wrote:
> checking for geos-config... /usr/bin/geos-config
> Usage: geos-config [OPTIONS]
Ok, forget about the '!' thing, what postgis does is call
geos-config with these:
GEOS_DIR=`$GEOSCONFIG --prefix`
GEOS_LDFLAGS=`$GEOSCONFIG --ldflags`
GEOS_MAJOR=`$GEOSCONFIG --version | cut -d. -f1`
It's possible that I forgot support for older geos and
the above are not actually working. So, can you try invoking
/usr/bin/geos-config with the above flags in turn and see
which fails ? Which version of GEOS do you have ?
(note that geos-config is a shell script, you can also inspect
with any pager or texteditor)
--strk;
