[postgis-users] Re: ver 1.1.5 configure fails on Ubuntu
strk at refractions.net
Fri Nov 10 08:09:38 PST 2006
On Fri, Nov 10, 2006 at 10:35:34AM -0500, Greg Troxel wrote:
> Thanks. Here's the workaround I have in place, which works fine.
> Plus, shouldn't that be -L${libdir} in your patch?
> (This patch is applied to postgis sources before building.)
> $NetBSD: patch-aa,v 1.1 2006/09/20 16:24:46 gdt Exp $
> --- configure.orig 2006-07-01 00:53:02.000000000 -0400
> +++ configure
> @@ -3735,7 +3735,7 @@ fi;
> if test $USE_GEOS -gt 0; then
> GEOS_DIR=`$GEOSCONFIG --prefix`
> - GEOS_LDFLAGS=`$GEOSCONFIG --ldflags`
> + GEOS_LDFLAGS=`$GEOSCONFIG --libs`
> GEOS_MAJOR=`$GEOSCONFIG --version | cut -d. -f1`
> if test "$GEOS_MAJOR" = "@GEOS_VERSION@"; then
> GEOS_MAJOR=1
--ldflags was introduced because dos not include -lgeos, so it
is usable to link against the C-API lib instead (-lgeos_c).
--libs will instead always add -lgeos.
So, with your patch, you'll end up with both -lgeos_c and -lgeos.
Not a big deal actually, as libgeos_c.so will link to libgeos.so
anyway, but it might link to a specific version of it instead
of the default one that would be found by -lgeos...
So, I'd recommend to try my patch first, which will be included
in next release.
> This patch (among others not relevant to this issue) is applied to
> geos 2.0.0. It's kludgy, but it gets -Wl,-R/usr/pkg/lib added like it
> should be.
mmm... I'm not sure we want to force that -rpath...
> $NetBSD: patch-ae,v 1.1 2006/09/20 16:01:48 gdt Exp $
> --- tools/geos-config.in.orig 2004-07-17 05:07:17.000000000 -0400
> +++ tools/geos-config.in
> @@ -34,7 +34,7 @@ case $1 in
> echo @CFLAGS@ -I at prefix@/include
> --libs)
> - echo -L at prefix@/lib -lgeos
> + echo -L at prefix@/lib @LDFLAGS@ -lgeos
> --includes)
> echo @prefix@/include
> So perhaps postgis should require a newer version of geos. When did
> -ldflags get added? I see 2.2.3 has it. (I'm currently building
> 2.2.3 with an uncommitted pkgsrc update, as that seems safer than
> 3.0.0rc right now.)
Postgis should work back to against GEOS-1.0.0, and I belive it still
does, and I'm also proud of it ;)
--strk;
