[postgis-users] Php interface for loading shp file into postgis
Luca Casagrande luca.casagrande at gmail.com
Tue Nov 14 01:14:41 PST 2006
Hi to all!
I am trying to found a good way to approach this issue:
i need to build a php interface that will do those tasks:
1) Load a shp file selected by the user;
2) Check if the file has got a prj file associated with it and if not
let the user insert the PROJ code for the current file;
3) Use proj to convert the file to the needed projection;
4) Store the file inside POSTGIS
The main thing i am thinking about, is when do the projection swap:
is it better to do BEFORE importing the data in POSTGIS or do just after the data has
been inserted inside Postgis?
Any feedback would be nice
Thank you very much
Luca
Help QGIS development! Make a donation right now at http://xrl.us/supportqgis
LINUX User #411601
GENTOO-GIS Development Team
jabber: casagrande at jabber.linux.it
