[postgis-users] Probelm with postgis-pg81-setup-1.1.6-1 in XP
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Tue Nov 14 02:13:02 PST 2006
> I had the same problem.
> I wanted to upgrade the Postgis install on WinXP.
> So I removed the postgis installation out of postgressql by the postgres
> installer.
> And indeed when re-installing postgis it generates errors.
> (Eventhough the postgres installer shows postgis is not installed
> (anymore))
> The only thing I could do (without loosing too much time over this) is
> unstalling postgres, reinstall it without postgis and do the postgis
> install
> separately.
> HIH, Jan
Hi Jan,
Thanks for your message - it does sound as if something is not working as
it should. If either you or Tomas can send me a copy of the log file
containing the errors offlist, I would be happy to take a look at it.
Kind regards,
Mark.
