[postgis-users] Hibernate with PostGIS
Dave Potts
dave.potts at pinan.co.uk
Sat Nov 18 09:07:48 PST 2006
First of all thank you Norman for writing the orginal code.
There is a slight problem with it, it does not handle a null geometry
column, rewritting nullSafeGet as follows, fixes the problem.
I can not say if it will address Sandeep problems, but it is worth trying.
David.
* @see
org.hibernate.usertype.UserType#nullSafeGet(java.sql.ResultSet,
java.lang.String[], java.lang.Object)
public Object nullSafeGet(ResultSet resultSet,
String[] names, Object owner) throws
HibernateException, SQLException {
Geometry result = null;
String geom = resultSet.getString(names[0]);
if(geom != null ) {
BinaryParser parser = new BinaryParser();
result = parser.parse(geom);
return result;
Sandeep Kumar Jakkaraju wrote:
> I think Hibernate cannot create that Geometry column automatically !!!
> is it something to do with hbm2ddl.auto !!
> I am able to ..get the geometry from a table with geometry column
> already created ...
> Norman -->> Would you like me to create a simple tutorial on how to
> use Hibernate with Postgis ..your tutorial .. is not easy to
> understand ...
> Thanks
> Sandeep
> postgis-users mailing list
