[postgis-users] looking for some perf data
raphael Jacquot
sxpert at sxpert.org
Tue Nov 21 09:14:44 PST 2006
Martin Davis wrote:
> First of all, you need to be more specific. The performance of an index
> is related to the kinds of queries you are making on it. If you are
> making a simple equality query, then a B-tree on the (x,y) pair is
> probably fine. But if you're wanting to do range searches in two
> dimensions, a B-tree does not support this kind of query, and hence
> performance will be slow compared to an access method which does support
> this (e.g. R-tree, quad-tree, etc etc).
typically I'm looking to compare using
create table blah1 (
lon double precision,
lat double precision
with one index on lon and another one on lat
the classic request being
lon>constant1 and lon<constant2 and lat>constant3 and lat<constant4
and
create table blah2 (
position Point
with a gist r-tree index
using the @ operator
> raphael Jacquot wrote:
>> hi there
>> I'm looking for some hard verifiable proof that using r-tree based
>> geometry indexes is better than using 2 columns and a btree index on
>> it, performance wise.
>> has there any study done on that ?
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
