[postgis-users] Re: looking for some perf data
Stephen Davies sdc at sdc.com.au
Tue Nov 21 15:39:40 PST 2006
Many years ago, I tried to implement a fairly simple GIS application
using separate B-trees on lat/long coordinates.
The idea died as soon as the data volumes became non-trivial.
The reason was obvious in hindsight: a query for x>=g1 and x <=g2 and
y>=t1 and y<=t2 using separate B-trees has to retrieve a "vertical" and
then a "horizontal" slice of the whole world and then take the
intersect.
R-trees, quad-trees etc greatly reduce this cost.
HTH,
Stephen Davies
This email is for the person(s) identified above, and is confidential to
the sender and the person(s).  No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting                            Voice: 08-8177 1595
Adelaide, South Australia.                             Fax: 08-8177 0133
Computing & Network solutions.                       Mobile:0403 0405 83
