[postgis-users] Identity Overlay
Paul Ramsey
pramsey at refractions.net
Wed Nov 22 12:06:38 PST 2006
This is such a common performance case, we're going to add some
automagical code to make Contains() work more efficiently, by
short-circuiting and Contains(POLYGON, POINT) cases directly to an
internal postgis PIP algorithm.
P
Stephen Woodbridge wrote:
> Try:
> UPDATE point_layer SET b250k_tag = polygon_layer.b250k_tag WHERE
> polygon_layer.the_geom && point_layer.the_geom and
> distance(polygon_layer.the_geom, point_layer.the_geom) < 0.00001;
> It is not good to compare floats with equals due to possible rounding
> errors.
> -Steve
> Aaron Koning wrote:
>> Hi All,
>> I am trying to perform an identity overlay where each point in a point
>> layer gets a value from a polygon layer based on what polygon contains
>> the point. I have come up with the following query which is working
>> fairly well.
>> contains(polygon_layer.the_geom, point_layer.the_geom);
>> I am just wondering if other people have performed identity like
>> overlays in PostGIS and is there a better / more efficient way to
>> perform them?
>> Thanks,
>> Aaron
>> | Aaron Koning
>> | Information Technologist
>> | Prince George, BC, Canada.
>> | Flexible Internet Spatial Template:
>> | http://fist-mapping.org
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
