[postgis-users] oid indexes issue
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Fri Nov 24 06:30:06 PST 2006
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Mark Cave-Ayland
> Sent: 24 November, 2006 9:12 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] oid indexes issue
> > Hi,
> > I'm attempting to recast a database instance with some scripts
> > developed against PostGIS 1.1.1.  Below is a code snippet
> of the init:
> > # CREATE TABLE service_endpoints (
> >  resource_id serial primary key,
> >  title text,
> > # SELECT AddGeometryColumn
> > ('service_endpoints','the_geom',4326,'MULTIPOLYGON',2);
> > # CREATE INDEX service_endpoints_idx ON service_endpoints
> USING GIST (
> > the_geom GIST_GEOMETRY_OPS );
> > # CREATE INDEX service_endpoints_idx_oid ON
> service_endpoints ( oid );
> > This works successfully against
> > - POSTGIS="1.1.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0,
> 22 Oct 2006"
> > USE_STATS DBPROC="0.3.0" RELPROC="1.1.1" (needs proc upgrade)
> > (1 row)
> > - PostgreSQL 8.1.2
> > - FC4
> > This does NOT work successfully against:
> > - POSTGIS="1.1.6" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0,
> 22 Oct 2006"
> > USE_STATS
> > - PostgreSQL 8.1.5
> > - MS Windows Server 2003
> > The error message I received when running against the latter
> > environment
> > is:
> > "ERROR:  column "oid" does not exist"
> > Are oid's no longer supported?
> > Thanks
> > ..Tom
> Hi Tom,
> Oids have been deprecated in PostgreSQL for several versions
> now, and since PostgreSQL 8.1 you need to explicitly enable
> them in postgresql.conf to support legacy applications. The
> chances are that your FC4 installation has had this setting
> changed from the default installation, while the new one hasn't.
> I would highly recommend that for future compatibility you
> should modify your application so it uses a different field
> (such as a primary key) instead of oid to help avoid this
> issue in future. One of the benefits of dropping oids is that
> you save an extra 4 bytes per row which can really add up
> when you are working with large tables.
Thanks for the info.  So should one still invoke the following:
