[postgis-users] postgis on fedora ...
Michael Fuhr
mike at fuhr.org
Sun Nov 26 09:28:46 PST 2006
On Sun, Nov 26, 2006 at 06:52:13PM +0530, Sandeep Kumar Jakkaraju wrote:
> when i am runnig this query
> select name from tiles where contains(tilebounds,GEOMFROMTEXT('POINT(0
> 0)'));
> I get this error :
> NOTICE: IllegalArgumentException: point array must contain 0 or >1 elements
> ERROR: POSTGIS2GEOS conversion failed
I'd guess that you have at least one bad geometry, e.g., a POLYGON
with a ring that has exactly one point. The following example
replicates the above error:
CREATE TABLE tiles (name text);
SELECT AddGeometryColumn('tiles', 'tilebounds', -1, 'GEOMETRY', 2);
INSERT INTO tiles (name, tilebounds) VALUES ('test', '0103000000010000000100000000000000000000000000000000000000');
SELECT name, AsText(tilebounds) FROM tiles;
name | astext
test | POLYGON((0 0))
(1 row)
SELECT name FROM tiles WHERE Contains(tilebounds, GeomFromText('POINT(0 0)'));
You might be able to find the bad geometry with isvalid() or
npoints():
SELECT name, AsText(tilebounds) FROM tiles WHERE NOT isvalid(tilebounds);
SELECT name, AsText(tilebounds) FROM tiles WHERE npoints(tilebounds) = 1;
Michael Fuhr
