AW: [postgis-users] -- Error running lwpostgis.sql --
Rafael Orta
rorta_us at yahoo.com
Sun Oct 1 13:17:59 PDT 2006
Thank you, that helped I copied the gis librarys to the place where the script was looking them
for and re-run the script, it seems to be working now. Thanks a lot :-)
cd /spatial/Postgis/Geos/geos-3.0.0rc1/capi/.libs
[root at spatial .libs]# cp * /usr/local/pgsql/lib/.
[root at spatial .libs]# ls -las /usr/local/pgsql/lib/libgeos_c.so.1
Sometimes you just need someone to tell you the abvious things because by nature you just think that it is way more complex.
Thanks again
Rafael Orta
----- Original Message ----
To: rorta_us at yahoo.com; PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Friday, September 29, 2006 2:59:20 AM
Subject: AW: [postgis-users] -- Error running lwpostgis.sql --
Hi!
You can try 'ldconfig' to reread all installed
libraries. Another way which was a solution sometimes, is to execute the
sql from the origin directory. Or you can exchange the variable $libdir in the
sql with the absolut path to liblwgeom.so.1 (on your own risk
Hope this was helpful.
bye
Uwe Seher
Von:
postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von
Rafael Orta
Gesendet: Freitag, 29. September 2006
05:37
An: postgis-users at postgis.refractions.net
Betreff:
Hello Everybody
I am new to install Postgis and I will appreciate your help, Installing
Postgis on Red Hat EE 4 I did the make and make install (as root) and I
do not see any errors , then I ran
psql -d smarter -f lwpostgis.sql and I get the following error
-bash-3.00$ psql -d smarter -f
lwpostgis.sql
BEGIN
psql:lwpostgis.sql:47: NOTICE: type
"histogram2d" is not yet defined
DETAIL: Creating a shell type
definition.
psql:lwpostgis.sql:47: ERROR: could not load library
"/usr/local/pgsql/lib/liblwgeom.so.1.1": libgeos_c.so.1: cannot open shared
object file: No such file or directory
psql:lwpostgis.sql:52: ERROR:
current transaction is aborted, commands ignored until end of transaction
block
I am not sure I installed the GEOS library (I don;t think I did at least
it comes as part of the POSTGIS rpm) and I am not sure how to install it
either but the POSTGIS Installation manual says that is it recommended which
makes me think it is optional.
Any idea about what could be happening here? My $libdir library points to
libdir=/usr/local/pgsql/lib
-bash-3.00$ cd /usr/local/pgsql/lib
-bash-3.00$
ls
ascii_and_mic.so
latin_and_mic.so
libecpg.so.5
libpgtypes.so
pgxs
utf8_and_euc_kr.so
utf8_and_sjis.so
cyrillic_and_mic.so
libecpg.a
libecpg.so.5.1 libpgtypes.so.2
plpgsql.so
utf8_and_euc_tw.so
utf8_and_uhc.so
euc_cn_and_mic.so
libecpg_compat.a
liblwgeom.so libpgtypes.so.2.1
utf8_and_ascii.so
utf8_and_gb18030.so
utf8_and_win1250.so
euc_jp_and_sjis.so
libecpg_compat.so
liblwgeom.so.1
libpq.a
utf8_and_big5.so
utf8_and_gbk.so
utf8_and_win1252.so
euc_kr_and_mic.so
libecpg_compat.so.2 liblwgeom.so.1.1
libpq.so
utf8_and_cyrillic.so utf8_and_iso8859_1.so
utf8_and_win1256.so
euc_tw_and_big5.so
libecpg_compat.so.2.1 libpgport.a
libpq.so.4
utf8_and_euc_cn.so utf8_and_iso8859.so
utf8_and_win1258.so
latin2_and_win1250.so
libecpg.so
libpgtypes.a
libpq.so.4.1
utf8_and_euc_jp.so
utf8_and_johab.so
utf8_and_win874.so
-bash-3.00$
Thanks in advance
Rafael
Orta
Rafael Orta Phone: (609)-330-3193
Sr. Oracle DBA Fax: (856)-642-7679
Technical Manager
Oraprofessionals Email: rorta_us at yahoo.com
Do you Yahoo!?
Everyone is raving about the all-new
Yahoo! Mail.
____________
Virus checked by G DATA AntiVirusKit
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061001/6ce92bfb/attachment.html>
