[postgis-users] Newcomer-performance issue
Carl Anderson carl.anderson at vadose.org
Sun Oct 1 17:30:25 PDT 2006
Pedro,
Looking at the spatial operator && (which utilized indexes)
I see that neither the Left or the Right side of the operator is a field
in a database tuple/record.
Both sides are the output of functions.
First, I don't believe that functions are indexable in PostgreSQL
Even if they are, I doubt you built such an index.
Both sides of the && operator are the results of a transform so a
regular GIST index is useless as a basis for an index scan.
Would it be possible to rewrite your test as
select name, city
from rede_estradas
where
geometry && setsrid(expand(transform(geomfromtext('POINT(-16.851888
32.646385)',4326),32628), 5), 32628) and
distance(transform(geomfromtext('POINT(-16.851888
32.646385)',4326),32628), transform(geometry,32628)) <=5
limit 1;
presuming that the geometry in rede_estradas is in SRID 32628 to start with.
If I was concerned about speed I would add an extra geometry column in
the projection 32628 to rede_estradas, and index it.
C.
Carl Anderson
GIS Manager
Fulton County Georgia, USA
Pedro Doria Meunier wrote:
> Hi list,
> This is my first post so, Hello from Madeira Is. !! J
> Now, I’ve been developing a fleet-tracking application and using (of
> course) pgsql/postgis.
> To be specific with my dilemma:
> I want to search for the road closest to a vehicle’s current
> coordinates, and I want to give a radius in **meters**.
> The road’s layer is in WGS84 as well as the current vehicle’s
> coordinates, so I have to reproject on the fly to a datum that allows
> me to work in metres; in this case WGS84 / UTM zone 28N.
> So here’s the query:
> select name, city from rede_estradas where
> transform(geometry,32628) &&
> and distance(transform(geomfromtext('POINT(-16.851888
> 32.646385)',4326),32628), transform(geometry,32628)) <=5 limit 1;
> Well… it ‘werks’… **but**! It takes ~1600ms to retrieve the result… L
> imagine this for a fleet of, say, 500 vehicles…
> I’m using Gist on the geometry column and VACCUM ANALYZEd the table.
> So, any of you Postgis gurus could point me to a way to speed up this
> query?
> Any help/info would be greatly appreciated!
> Best regards,
> _Pedro Doria Meunier_
> (351) 91 302 49 72 - (351) 96 247 99 12
> MSN - pdoriam at hotmail.com <mailto:pdoriam at hotmail.com>
> ICQ - 308-182-126
> Skype: pdoriam
> postgis-users mailing list
