[postgis-users] data base structure for holding climate data
Kirk R. Wythers kwythers at umn.edu
Tue Oct 3 06:13:59 PDT 2006
Hey Brent Thanks for the reply.
On Oct 2, 2006, at 2:22 PM, Brent Wood wrote:
> --- "Kirk R. Wythers" <kwythers at umn.edu> wrote:
>> I am curious as to the consensus approach to handling dates in
>> postgis? I have gathered up a fairly large collection of climate
>> data. The date fields however, came parsed in the form
>> (year,month,day). I want to set up a postgres database to hold this
>> data with a location structure along the lines of:
> Hi Kirk,
> Nice to see you're really moving with this stuff :-)
> We use Oracle, but comparable structures using the native time
> datatype. We are
> also using Informix, which is uniquely suited to such data as it
> not olnly has
> a spatial datablade (similar to PostGIS) but has a timeseries
> datablade which
> does for timeseries data pretty much what PostGIS does for spatial
> data.
These postgis questions are part of a larger idea to write one of my
ecosystem simulation models into GRASS as a module. The first hurdle
however, is to deal with time series formatted input files (namely
climate data), and time series format output files.
> However, for PostGIS, I suggest you look at a timestamp for
> identifying just
> when a record was captured. For queries & aggregating (eg: to
> extract avg
> daily/weekly/monthly temps) it will be useful to de-normalise &
> also store
> separately indexed componenets of the timestamp, such as date, week
> of year,
> month of year etc...
I'm not sure I quite follow you here. I will want to do as you say
above and query for avg daily,weekly,monthly temps, solar etc. How
will de-normalising the data facilitate that? Climate data is already
some what de-normalised in that solar radiation comes in separate
files from temps and precipitation data.
> One other aspect will depend on your data. We have a PostGIS table
> with some
> 200,000,000 instrument readings, using a clustered index on
> timestamp, and
> comprising yearly partitions. The raw data stores the actual time
> of data
> capture, but the various instruments are not syncronised, so it is
> not possible
> to extract a snapshot of them all at a common time.
> We post process the data to generate a table (the 200,000,000
> record one) which
> has a record for every 1 min interval, with each reading where the
> reading is
> the latest one within that 1 minute interval.
> Some what impressively, a self-relation across this table with 25
> readings,
> retrieving 3 months data at 10 min intervals only takes 25 seconds
> on a desktop
> PC.
That is impressive!
> To facilitate extarction at different intervals, each record also
> has an
> attribute of 1, 2, 5, 10, 30, 60, 120, 1440 (based on minutes) so
> we can get
> two-hourly values by using "where time_flag=120")
> Hope this helps....
>    Brent
>> mn_climate=# \d sites
>>                  Table "public.sites"
>>       Column     |         Type          | Modifiers
>> site_id        | integer               |
>> site_shortname | character varying(8)  |
>> site_name      | character varying(50) |
>> lat            | numeric               |
>> lon            | numeric               |
>> utm_e          | numeric               |
>> utm_n          | numeric               |
>> Indexes:
>>      "sites_site_id_key" UNIQUE, btree (site_id)
>> And tie this "site" table to a second "clim" table that holds the
>> actual meteorological data. However, I am inclined to concatenate the
>> year, month, day data into a single "date" data type of the form
>> year-
>> month-day-hour-minute-second (yyyy-mm-dd-hh-mm-ss). Does this make
>> sense to you all? If anyone can re-direct me before I do something
>> dumb in way I set this up, I would appreciate it.
>> Thanks,
>> Kirk
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
