[postgis-users] Transform not transforming longitude
Nathaniel
naptrel at yahoo.co.uk
Wed Oct 4 13:31:45 PDT 2006
Hello all,
I've recently installed PostGIS/Proj4/GEOS.
Calls to Transform() between two datums (Eg
WGS84->NAD27, WGS84->ED50) are not altering the
longitude. Also, the latitude change is not exactly
right (compared to other reliable transformers).
Is this something that other users have experienced?
Installation on Mac OS X was completely trouble-free
and by-the-book, so my hunch is that the error is my
ignorance.
My guess is that the Transform call is not doing a
datum shift, but rather is just reprojecting onto the
new ellipsoid. If this is the case, what do I have to
do to shift datums?
Thanks in advance for any help.
Here's an example:
select srid(geom) AsText(geom) from gtest;
srid | astext
4326 | POINT(-3.51885 56.50298)
select AsText(Transform(geom,4320)) from gtest;
astext
POINT(-3.51885 56.503736259005)
___________________________________________________________
Try the all-new Yahoo! Mail. "The New Version is radically easier to use" – The Wall Street Journal
http://uk.docs.yahoo.com/nowyoucan.html
