This is more of a straight postgreSQL question, but does pertain to a postGIS table. I want to dump a very large table into separate tables by year. For instance, SELECT * FROM dg WHERE date = '2002';, and dump the result into a sql file, preferably with inserts into a table named dg2002. Thanks! Sean
