[postgis-users] problem using JDBC PreparedStatement
Just van den Broecke
just at justobjects.nl
Mon Oct 9 15:43:55 PDT 2006
I have a problem using prepared statements for insert/update with JDBC
(org.postgis.DriverWrapperLW).
For example the PreparedStatement
INSERT INTO spatialone VALUES (?,?,?,?,?)
expands into
(28,TheName,1160432443975,1160432443975,GeomFromText('POINT (4.92
52.35)', 4326))
On execute this gives the error:
"org.postgresql.util.PSQLException: ERROR: column "point" is of type
geometry but expression is of type character varying"
Prepared inserts/updates using class PGgeometryLW for this table work ok.
I've seen earlier posts on a similar issue, tried omitting/escaping the
single quotes but to no avail. Below my version info. Thanks,
--Just
- version test
** PostGIS jdbc client code **
getFullVersion: PostGIS JDBC V1.1.0
** PGJDBC Driver **
getVersion: PostgreSQL 8.1 JDBC3 with SSL (build 407)
getMajorVersion: 8
getMinorVersion: 1
** PostgreSQL Server **
version: PostgreSQL 8.1.3 on i686-apple-darwin8.7.1, compiled by GCC
i686-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc. build 5363)
** PostGIS Server **
postgis_version: 1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
postgis_proj_version: Rel. 4.4.9, 29 Oct 2004
postgis_scripts_installed: 1.1.1
postgis_lib_version: 1.1.1
postgis_scripts_released: 1.1.1
postgis_uses_stats: t
postgis_geos_version: 2.2.1-CAPI-1.0.1
postgis_scripts_build_date: 2006-10-04 08:22:06
postgis_lib_build_date: 2006-10-04 08:22:06
postgis_full_version: POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1"
PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
