[postgis-users] Help wanted creating a custom equal area projection in spatial_ref_sys
Brent Wood
pcreso at pcreso.com
Tue Oct 10 15:34:21 PDT 2006
I'm trying to create a custom projection around New Zealand for working with
polygon areas. Any comments/advice appreciated.
I figure the following will be as appropriate as anything, please let me know
if I'm wrong!
Albers Conical Equal Area
std parallel -30
" " -50
lon of central meridian 175
lat of origin -40
false easting 0
false northing 0
datum WGS84
ellipsoid WGS84
If this is indeed suitable, then if I've got the proj4 command line right, an
SQL to create this in the spatial_ref_sys table would be:
insert into spatial_ref_sys
(srid,
auth_name,
auth_srid,
proj4text)
values
(27201,
'BEN200601',
27201,
'+proj=aea +lat_1=-30 +lat_2=-50 +lat=-40 +lon_0=175 +x_0=0 +y_0=0
+ellps=WGS84 +datum=WGS84 +units=m +no_defs'
Thanks,
Brent Wood
